2.0 Abarth Motor
Falls noch einer von Euch auf der Suche sein sollte, soeben entdeckt aber für den Längseinbau so nicht geeignet...
http://www.ebay.de/itm/Fiat-ABARTH-Motor-2l-130-125-TC-124-Spider-Lancia-Montecarlo-Bertone-X1-9-/170749622375?pt=DE_Autoteile&hash=item27c1787867
Schönen Abend
Bild des Benutzers Sealord69
Sealord69
Last seen: vor 9 Jahre 3 Monate
Beigetreten: 06.09.2012 - 21:38
Re: 2.0 Abarth Motor
Ich habe aktuell mit einem Holländer Kontakt, der hat ein nicht unerhebliches Abarth TC Arsenal.
Sollte jemand an den Kontaktdaten interesse haben bitte eine PN:
Ich habe mal einen Teil aus dem Mailverkehr angehängt.
1 130 TC head with banks and cams original € 350,-
1 105 TC head with banks and cams original. € 300,-
1 130 TC (race) head completely flowed with reshaped cams for a higher lift. (huge inlets )
I have no specifications upon this head, should be measured out completely. € 350,-
2 sets of 130 TC cams. € 100,- per set.
Several S73 heads with big Valves. (43,5 mm/ 36 mm) € 200,-
Among a Lancia head with 42,5 mm inlet valves ???
Sevaral S62 heads with normal 41,5 mm/ 36 mm Valves. € 100,-
Also and maybe interesting for you
A bare 138 AR 1000 (130TC) engineblock, that has to be rebored to accept oversized pistons.
without crank but with measure report , special priced for you € 150,-
with crank makes it € 250,- and flywheel € 325,-
As already mentioned the complete 130 TC engine 138 AR 1000
Overhauled (oversized bearings) and with clutch, waterpump, timing belt, and tensioner.
and big volume oil-pump
one factory new 2 liter engine block (was an automatic).
Dome-less pistons.
crank reworked to accept gearbox. (€ 850,-)
a set of reworked high dome pistons, and a set of reworked rods (lightened)
one 128.000 km Lancia Volumex engine ( € 750,-)
Many motorparts to build it either ignition on top or at the side of the engine
electronic Ignitions also digiplex, as well as carburators (for building 125 TC)
There must be a lot I forget now, but this is to give you an insight.
And If you want I'll give you € 100,- for your old engine, that depends on what you want to buy
Bild des Benutzers sirion
sirion
Beigetreten: 05.09.2012 - 07:09
AW: 2.0 Abarth Motor
Schönen Abend
Mal sehen wie oft der Motor noch bei eBay drin ist....
War mindestens schon zwei mal im Angebot.
Schöne Feiertage
Sven
Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe (Walter Röhrl)
Last seen: vor 2 Jahre 1 Monat
Teile mit Verkaufslackierung wirken schnell unseriös ...
